Google Home Interconnect Cable Replacement
  1. Google Home Interconnect Cable Replacement, Interconnect Cable: step 1, image 1 of 3 Google Home Interconnect Cable Replacement, Interconnect Cable: step 1, image 2 of 3 Google Home Interconnect Cable Replacement, Interconnect Cable: step 1, image 3 of 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Interconnect Cable Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully remove the interconnect cable using a pair of tweezers.
Gabe Hyun
826 Reputation
4 Guides authored
Cal Poly, Team S24-G11, Maness Spring 2018 Member of Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Members
5 Guides authored
One Comment
What cord can you replace with? There is an adaptor attached.
Katti Sundelin - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 690
