Google Chromebook Pixel 2 Fan Replacement
  1. Google Chromebook Pixel 2 Fan Replacement, Back Panel: step 1, image 1 of 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Fan Replacement: step 2, image 1 of 1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Fan Replacement: step 3, image 1 of 2 Google Chromebook Pixel 2 Fan Replacement: step 3, image 2 of 2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Fan Replacement: step 4, image 1 of 1
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Fan Replacement, Fan: step 5, image 1 of 2 Google Chromebook Pixel 2 Fan Replacement, Fan: step 5, image 2 of 2
    • Remove the three blue 4.0 mm Phillips #00 screws from the fan on the right side.
  6. Google Chromebook Pixel 2 Fan Replacement: step 6, image 1 of 1
    • Using the plastic opening tool, slide out the right fan’s connector out of the motherboard slot.
  7. Google Chromebook Pixel 2 Fan Replacement: step 7, image 1 of 1
    • Carefully remove lift the right fan out of its slot.
  8. Google Chromebook Pixel 2 Fan Replacement: step 8, image 1 of 2 Google Chromebook Pixel 2 Fan Replacement: step 8, image 2 of 2
    • Remove three blue 4.0 mm Phillips #00 screws from the left fan.
  9. Google Chromebook Pixel 2 Fan Replacement: step 9, image 1 of 1
    • Using the plastic opening tool, slide out the left fan’s connector.
  10. Google Chromebook Pixel 2 Fan Replacement: step 10, image 1 of 1
    • Gently lift the left fan out of its slot.
Garrett Monteiro
413 Reputation
3 Guides authored
Cal Poly, Team S22-G6, Livingston Spring 2017 Member of Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 141
