Shop the Holiday Gift Guide
GoPro Karma Harness Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
54
All Time:
1,788
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the harness for the GoPro camera is fairly easy. We will tell you how to remove the stabilizer which holds the harness, how to remove camera from the harness, and how to replace the harness itself.
Tools
    1. GoPro Karma Harness Replacement, Stabilizer: step 1, image 1 of 3 GoPro Karma Harness Replacement, Stabilizer: step 1, image 2 of 3 GoPro Karma Harness Replacement, Stabilizer: step 1, image 3 of 3
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
      Ask FixBot
    2. GoPro Karma Harness Replacement: step 2, image 1 of 1
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
      Ask FixBot
    1. GoPro Karma Harness Replacement, Harness: step 3, image 1 of 3 GoPro Karma Harness Replacement, Harness: step 3, image 2 of 3 GoPro Karma Harness Replacement, Harness: step 3, image 3 of 3
      • Place finger on the tab to open the harness and remove the camera.
      • Be sure to pull the camera straight out lest you damage the connectors.
      Ask FixBot
    2. GoPro Karma Harness Replacement: step 4, image 1 of 1
      • Using a Hex 2.0mm screwdriver, remove the two 12 mm hex screws closest to the harness.
      Ask FixBot
    3. GoPro Karma Harness Replacement: step 5, image 1 of 3 GoPro Karma Harness Replacement: step 5, image 2 of 3 GoPro Karma Harness Replacement: step 5, image 3 of 3
      • Pull the harness off of the stabilizer.
      • Be sure to pull the harness straight off lest you damage the connector.
      Ask FixBot
Author
with
Max Verspieren
97 Reputation
1 Guide authored
Cal Poly, Team S25-G14, Maness Spring 2018 Member of Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 54
All Time: 1,788
