You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
In this guide we will be showing you how to replace the port assembly in your GoPro Hero4 Silver. This port is used to connect LCD devices, external battery packs, and other accessories. Before you begin make sure the battery is removed from the device and that you have the necessary tools to preform this repair.
  1. Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on. The seven plastic tab locations are marked in red. Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
    • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
    • The seven plastic tab locations are marked in red.
    • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
    • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
  2. Remove the three 8 mm Phillips #000 screws on each corner of the camera.
    • Remove the three 8 mm Phillips #000 screws on each corner of the camera.
    • Remove the single 4 mm Phillips #000 screw on the bottom left corner of the camera.
  3. To remove the motherboard assembly from the camera casing, use the plastic opening tool on the lens side of the camera to pry the motherboard assembly out of the camera housing. To avoid breaking the plastic on the lens side of the camera (see photo), pry along the edges near the corners.
    • To remove the motherboard assembly from the camera casing, use the plastic opening tool on the lens side of the camera to pry the motherboard assembly out of the camera housing.
    • To avoid breaking the plastic on the lens side of the camera (see photo), pry along the edges near the corners.
    • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the motherboard assembly open, but found that it did not give us enough leverage.
    • Do not try to pry near the power button side of the camera. This will break important cables inside.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Shop Now
    Android Fix Kits
    Shop Now
  5. Remove the four 8 mm Phillips #000 screws securing the camera sensor assembly. Remove the four 8 mm Phillips #000 screws securing the camera sensor assembly.
    • Remove the four 8 mm Phillips #000 screws securing the camera sensor assembly.
  6. To remove the sensor assembly, simply peel  off the lens towards the attached ribbon cable. The sensor has ribbon cables running to the motherboard via a black rectangular connector. To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
    • To remove the sensor assembly, simply peel off the lens towards the attached ribbon cable.
    • The sensor has ribbon cables running to the motherboard via a black rectangular connector.
    • To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
    • With the old camera sensor assembly removed, you can now replace it with a new sensor.
  7. Remove the three 8 mm Phillips #000 screws securing the Hero port to the motherboard.
    • Remove the three 8 mm Phillips #000 screws securing the Hero port to the motherboard.
  8. Locate the copper-colored ribbon cables connecting the Hero Port to the motherboard.
    • Locate the copper-colored ribbon cables connecting the Hero Port to the motherboard.
    • To remove the connector, use tweezers or a spudger, pry up each side of the connector. Then, lift the connector straight up from it's socket.
    • When reassembling this piece, do not use too much force to put the black rectangular pins back onto the motherboard. When done right, there will be a 'click'.
  9. To remove the free port, simply slide it out from the left side of the camera. It should come out with slight coercion.
    • To remove the free port, simply slide it out from the left side of the camera. It should come out with slight coercion.
    • This piece can be replaced, fixed, or set aside for further tear-down of the GoPro.
    • Pictured left is the port when separated from the motherboard.
Bradley Welsh
677 Reputation
2 Guides authored
USF Tampa, Team 2-1, Blackwell Fall 2015 Member of USF Tampa, Team 2-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G1
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 62
All Time: 5,896
