Introduction
Oops! You scratched the front of your GoPro and you don't want others to question if you take care of your camera. Let's replace that face plate and make it look good as new!
  1. Insert a plastic opening tool in between the front face plate and the black housing.
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  3. Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
4 other people completed this guide.
Patrick Cook
655 Reputation
3 Guides authored
Cal Poly, Team 5-8, Maness Fall 2015 Member of Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 369
