GoPro Hero3+ Black Edition microSD and Accessory Board Replacement
  1. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Battery: step 1, image 1 of 1
    • Pull the tab on the back of the device to release the back cover. It should come right off.
    • The device pictured does not include the back cover.
  2. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 2, image 1 of 1
    • Use the battery tab to pull the battery out of the device.
    • Remove the battery from the slot.
  3. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Front Face Plate: step 4, image 1 of 2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Front Face Plate: step 4, image 2 of 2
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
  4. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Image Sensor: step 5, image 1 of 3 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Image Sensor: step 5, image 2 of 3 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Image Sensor: step 5, image 3 of 3
    • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
    • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
    • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
  5. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 6, image 1 of 2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 6, image 2 of 2
    • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
  6. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 7, image 1 of 1
    • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
    • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
  7. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 8, image 1 of 1
    • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
    • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
  8. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 9, image 1 of 2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 9, image 2 of 2
    • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
    • Remove the image sensor from the motherboard assembly.
  9. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, microSD and Accessory Board: step 10, image 1 of 1
    • Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
  10. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 11, image 1 of 2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: step 11, image 2 of 2
    • Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
    • The microSD/accessory board is ready to come off.
6 other people completed this guide.
Kyle Rooney
502 Reputation
3 Guides authored
Cal Poly, Team 6-15, Maness Spring 2015 Member of Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
4 Members
13 Guides authored
One Comment
I bought a replacement from iFixit. I follow the guide, but it still shows same error “No SD”. Any advice?
Daniel Nielsen - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 12
All Time: 2,094
