Shop the Holiday Gift Guide
GoPro Hero Casing Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
12
All Time:
491
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
In order to replace or fix components in this camera, it is necessary to take of the back and get to the "guts" of the camera. This is because the camera does not come out of the case.
Parts
Tools
    1. GoPro Hero Casing Replacement, Casing: step 1, image 1 of 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Ask FixBot
    2. GoPro Hero Casing Replacement: step 2, image 1 of 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Ask FixBot
    3. GoPro Hero Casing Replacement: step 3, image 1 of 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      Ask FixBot
    4. GoPro Hero Casing Replacement: step 4, image 1 of 1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      Ask FixBot
    5. GoPro Hero Casing Replacement: step 5, image 1 of 1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      Ask FixBot
    6. GoPro Hero Casing Replacement: step 6, image 1 of 1
      • Carefully remove the motherboard and white plastic piece from the case.
      Ask FixBot
Author
with
River Drake
1,065 Reputation
5 Guides authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 491
