GoPro HD Hero2 SD Board Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. GoPro HD Hero2 SD Board Replacement, SD Board: step 1, image 1 of 1
      • Remove the two 5.8 mm Phillips #00 screws securing the SD board cover to the rear case.
      Ask FixBot
    2. GoPro HD Hero2 SD Board Replacement: step 2, image 1 of 3 GoPro HD Hero2 SD Board Replacement: step 2, image 2 of 3 GoPro HD Hero2 SD Board Replacement: step 2, image 3 of 3
      • Turn the rear case over so that the SD card slot is facing you.
      • Use the tip of a spudger to push the bottom of the SD board cover up and out of the rear case.
      • Turn the rear case back over.
      • Lift the SD board cover out of the rear case with the tip of a spudger and remove it.
      Ask FixBot
    3. GoPro HD Hero2 SD Board Replacement: step 3, image 1 of 2 GoPro HD Hero2 SD Board Replacement: step 3, image 2 of 2
      • Grasp the SD board ribbon cable gently and pull the SD board out of the rear case.
      Ask FixBot
David Hodson
156,996 Reputation
127 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 545
