Gigabyte P34G Solid State Drive Replacement
    1. Gigabyte P34G Solid State Drive Replacement, Solid State Drive: step 1, image 1 of 1
      • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
      • There are three different sized screws.
      • x1 9.8mm Screw
      • x8 5.6mm Screws
      • x6 5.0mm Screws
      • Divide the screws by size and save them in a safe space for reassembly later.
      Ask FixBot
    2. Gigabyte P34G Solid State Drive Replacement: step 2, image 1 of 1
      • Unscrew the marked 4.5mm screw with a #0 screwdriver.
      • Set the screw aside to use for reassembly after replacing the solid state drive.
      Ask FixBot
    3. Gigabyte P34G Solid State Drive Replacement: step 3, image 1 of 1
      • Carefully pull the solid state drive in the direction shown to disconnect it from the port.
      Ask FixBot
yeunghayden
841 Reputation
6 Guides authored
Cal Poly, Team 8-1, Regan Spring 2015 Member of Cal Poly, Team 8-1, Regan Spring 2015
CPSU-REGAN-S15S8G1
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 95
All Time: 2,230
