Gigabyte P34G Battery Replacement
  1. Gigabyte P34G Battery Replacement, Battery: step 1, image 1 of 1
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
  2. Gigabyte P34G Battery Replacement: step 2, image 1 of 1
    • Unscrew the 4 marked 4.5mm screws using a #0 screwdriver.
    • Save the screws in a safe place for reassembly later.
  3. Gigabyte P34G Battery Replacement: step 3, image 1 of 1
    • Pull the wires down towards yourself to disconnect the attached connector.
  4. Gigabyte P34G Battery Replacement: step 4, image 1 of 1
    • Carefully lift the battery for removal.
yeunghayden
841 Reputation
6 Guides authored
Cal Poly, Team 8-1, Regan Spring 2015 Member of Cal Poly, Team 8-1, Regan Spring 2015
CPSU-REGAN-S15S8G1
5 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 36
All Time: 19,374
