General - How to repair broken parts
Video Overview
  1. General - How to repair broken parts, Glass sand and cyan acrylate glue: step 1, image 1 of 1
    • You need cyan acrylate glue and glass sand with a particle size of 0.05 to 0.5 mm.
    • Glass sand has the advantage that it is alkaline and therefore the glue cures rapidly.
  2. General - How to repair broken parts, Have activator on hand: step 2, image 1 of 1
    • To speed up curing activator helps a lot.
  3. General - How to repair broken parts, clean damage area: step 3, image 1 of 2 General - How to repair broken parts, clean damage area: step 3, image 2 of 2
    • Make sure, the glueing areas a free of dirt, dust and grease.
  4. General - How to repair broken parts, Add glue: step 4, image 1 of 1
    • Add a little glue onto the damage area.
  5. General - How to repair broken parts, Scatter glass sand: step 5, image 1 of 1
    • Scatter glass sand onto the glue and wait until it's cured. Eventually spray a little activator onto it.
  6. General - How to repair broken parts, Add more glue: step 6, image 1 of 1
    • Add more glue
  7. General - How to repair broken parts, Add more glass sand: step 7, image 1 of 1
    • Again scatter glass sand onto the glue. Alternating add glass sand and glue until the desired layer thickness has reached.
  8. General - How to repair broken parts, After curing: step 8, image 1 of 2 General - How to repair broken parts, After curing: step 8, image 2 of 2
    • As soon as the desired layer thickness has reached and the glue is cured, the parts may be strained.
Low viscous cyan acrylate glue is better for this technic than the jelly like glue, because it sucks more easily into the gaps in between the glass particles.
Glass sand has the advantage that it is alkaline and therefore the super glue hardens quite fast. In principle you may add as many glass layers as you like to build for example reinforcement ribs or bridges. In addition you may fill layer-wise holes or cracks this way. Excessive material may be cut off using a scalpel. Also post processing by filing or sandig works fine.
The glass sand scattering technic is also working well to repair broken porcellain or ceramics.
Unfortunately not all plastic material can be easily glued. Especially with poly ethylene, poly propylene an Teflon superglue needs a primer.
Rolf Jethon
313 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 184
