General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement
  1. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement, Reverse Switch: step 1, image 1 of 1
    • Before you begin, make sure the drain cleaner is disconnected from power.
    • Use a Phillips #2 driver to remove the two screws securing the control box cover.
  2. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 2, image 1 of 1
    • Remove the control box cover.
  3. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 3, image 1 of 1
    • Use a 9/16 inch deep socket and ratchet to remove the nut securing the reverse switch.
  4. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 4, image 1 of 1
    • Remove the reverse switch guard.
  5. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 5, image 1 of 2 General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 5, image 2 of 2
    • Squeeze the tabs on either side of the reverse switch connector.
    • Pull the two halves of the connector apart to disconnect it.
    • Take note of where everything is connected in the control box before disconnecting anything else.
  6. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 6, image 1 of 2 General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 6, image 2 of 2
    • Pull the white cable straight off of its spade connector on the power switch diaphragm.
  7. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 7, image 1 of 2 General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 7, image 2 of 2
    • Pull the black cable straight off of its spade connector on the power switch diaphragm.
  8. General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 8, image 1 of 3 General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 8, image 2 of 3 General Pipe Cleaners Drain Cleaner PMEBO 2016 Reverse Switch Replacement: step 8, image 3 of 3
    • Slide the switch assembly down out of its hole in the control box and pull it out of the control box.
    • Be careful not to snag the switch on any cables during removal.
Adam O'Camb
217,282 Reputation
416 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 16
All Time: 827
