GeeksPhone Keon Motherboard Replacement
  1. GeeksPhone Keon Motherboard Replacement, Battery: step 1, image 1 of 2 GeeksPhone Keon Motherboard Replacement, Battery: step 1, image 2 of 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Motherboard Replacement: step 2, image 1 of 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Motherboard Replacement: step 3, image 1 of 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon Motherboard Replacement, Back Plate: step 4, image 1 of 2 GeeksPhone Keon Motherboard Replacement, Back Plate: step 4, image 2 of 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon Motherboard Replacement: step 5, image 1 of 2 GeeksPhone Keon Motherboard Replacement: step 5, image 2 of 2
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon Motherboard Replacement: step 6, image 1 of 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon Motherboard Replacement: step 7, image 1 of 3 GeeksPhone Keon Motherboard Replacement: step 7, image 2 of 3 GeeksPhone Keon Motherboard Replacement: step 7, image 3 of 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon Motherboard Replacement: step 8, image 1 of 2 GeeksPhone Keon Motherboard Replacement: step 8, image 2 of 2
    • Lift the backplate away from the device.
  9. GeeksPhone Keon Motherboard Replacement, Motherboard: step 9, image 1 of 2 GeeksPhone Keon Motherboard Replacement, Motherboard: step 9, image 2 of 2
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
  10. GeeksPhone Keon Motherboard Replacement: step 10, image 1 of 1
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
  11. GeeksPhone Keon Motherboard Replacement: step 11, image 1 of 1
    • Remove the motherboard from the device.
Yanni Worthington
325 Reputation
3 Guides authored
USF Tampa, Team 3-5, Eyestone Fall 2015 Member of USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 158
