GeeksPhone Keon Battery Replacement
    1. GeeksPhone Keon Battery Replacement, Battery: step 1, image 1 of 2 GeeksPhone Keon Battery Replacement, Battery: step 1, image 2 of 2
      • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
      • Slide the plastic opening tool from the bottom of the phone to the top.
      • Use the plastic opening tool to free all the clips attached to the phone.
      Ask FixBot
    2. GeeksPhone Keon Battery Replacement: step 2, image 1 of 1
      • Lift the cover away from the phone.
      Ask FixBot
    3. GeeksPhone Keon Battery Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
      • Lift the battery with the plastic opening tool and finish removing battery by hand.
      Ask FixBot
Yanni Worthington
343 Reputation
3 Guides authored
USF Tampa, Team 3-5, Eyestone Fall 2015 Member of USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Members
72 Guides authored
4 Guide Comments
Newer Keon model has user replaceable battery GP-BA002
gintasdx - Reply Share
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - Reply Share
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - Reply Share
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 74
All Time: 1,161
