Up to 20% off select tools
GeeksPhone Keon Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
90
All Time:
679
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Note: The motherboard does not have to be removed from the phone in order to remove the camera.
This guide can be used to replace the camera if it is no longer working properly.
    1. GeeksPhone Keon  Camera Replacement, Battery: step 1, image 1 of 2 GeeksPhone Keon  Camera Replacement, Battery: step 1, image 2 of 2
      • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
      • Slide the plastic opening tool from the bottom of the phone to the top.
      • Use the plastic opening tool to free all the clips attached to the phone.
      Ask FixBot
    2. GeeksPhone Keon  Camera Replacement: step 2, image 1 of 1
      • Lift the cover away from the phone.
      Ask FixBot
    3. GeeksPhone Keon  Camera Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
      • Lift the battery with the plastic opening tool and finish removing battery by hand.
      Ask FixBot
    1. GeeksPhone Keon  Camera Replacement, Back Plate: step 4, image 1 of 2 GeeksPhone Keon  Camera Replacement, Back Plate: step 4, image 2 of 2
      • Remove the two 5mm T4 screws on the sides of the small orange plate.
      Ask FixBot
    2. GeeksPhone Keon  Camera Replacement: step 5, image 1 of 2 GeeksPhone Keon  Camera Replacement: step 5, image 2 of 2
      • Gently remove the small orange plate by pulling it down.
      Ask FixBot
    3. GeeksPhone Keon  Camera Replacement: step 6, image 1 of 1
      • Remove the following screws securing the back plate to the device:
      • Two silver 2mm T3 screws
      • Five black 3mm T3 screws
      Ask FixBot
    4. GeeksPhone Keon  Camera Replacement: step 7, image 1 of 3 GeeksPhone Keon  Camera Replacement: step 7, image 2 of 3 GeeksPhone Keon  Camera Replacement: step 7, image 3 of 3
      • Slightly lift up the bottom corner of the backplate.
      • Release the four clips on both sides by pulling them away from the device.
      Ask FixBot
    5. GeeksPhone Keon  Camera Replacement: step 8, image 1 of 2 GeeksPhone Keon  Camera Replacement: step 8, image 2 of 2
      • Lift the backplate away from the device.
      Ask FixBot
    1. GeeksPhone Keon  Camera Replacement, Camera: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Lift the retaining flap on camera's ZIF connector.
      • Pull the ribbon cable away with tweezers.
      Ask FixBot
    2. GeeksPhone Keon  Camera Replacement: step 10, image 1 of 3 GeeksPhone Keon  Camera Replacement: step 10, image 2 of 3 GeeksPhone Keon  Camera Replacement: step 10, image 3 of 3
      • Carefully wiggle the camera away from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order; but remember, the new camera must be glued back in place where the old one was removed.
Author
with
Bryan Bittner
167 Reputation
1 Guide authored
USF Tampa, Team 3-5, Eyestone Fall 2015 Member of USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 90
All Time: 679
