Introduction
Go to step 1 ↓In this guide, we will be disassembling the Geek Chef 4 Slice toaster, displaying the processes needed to take apart all of the different complex pieces of the toaster design, thus showing how to get to different parts of the toaster that might need to be repaired.
Ensure that the device isn't plugged into an electrical outlet while disassembling to prevent electrocution, and make sure you're careful with the toaster, especially the internal components as they could be damaged or break completely.
Additionally, we will only be disassembling one slice-worth of one side of the toaster, but all of the steps can be replicated for all sides and slices-worth of the toaster, although the orientations may be slightly different, the pieces are the same.
Tools
Carefully bend the metal tabs at the rear of the bottom toast holders so they can fit through the slot at the back.
Push these two arms up so the angled arms (jutting out from the middle of each toast holder) fit through the top y-shaped cutout on the toasting body.
Slide out these holders by pulling the module and wiggling it by the black plastic that holds the two pieces together.
Gently remove both toast holding metal pieces.
This will require slightly bending the front and back of the toasting body outward to allow for the small rods, circled in red, to be released.
The small arms must also be maneuvered out of the holes provided to remove the toast holding metal pieces.
