Community-Contributed Guide
Introduction
Go to step 1 ↓Prerequisite only guide for removing the tank cover.
Tools
Grasp the mouthpiece with a pair of pliers.
Give it a good, solid twist, left or right doesn't matter.
Hopefully the mouthpiece seal stays in place when you removed the mouthpiece, but it doesn't always. If it has come off, you need to know how to replace it.
It is inserted into the mouthpiece with the felt piece up. Putting it in the other way will not allow for an airtight seal between the tank and the mouthpiece.
Note that the mouthpiece has a tab that only allows it to be mounted in one orientation. The arrow here points to the one you'll need to match up with on the case.
Here you can see inside the case where the tab on the mouthpiece lines up.
Turn the power switch to the Off position; no air holes should be visible.
Use your utility knife to lever the power button up. It is only pressed on, so there is no adhesive or clips to deal with.
Remove the power button.
The clips should be free all the way around at this point.
Pull the vape straight out of the case.
