Introduction
I have created this guide for the reader with minimal-to-intermediate technical experience. I estimate that most readers can complete my guide within 15-25 minutes. To complete the guide's steps, the only tool you will need is a #1 Phillips screwdriver. As an outline of my procedure, I will remove the laptop’s backing, access the hard drive, disconnect it, and replace it with a working hard drive. My guide is helpful, because it shows you how to fix a 2014 laptop, a cost-effective alternative to your purchasing a new laptop.
Ensuring the laptop is turned off, flip the laptop upside down.
Remove the single Phillips #1 screw in the laptop bottom casing.
Tilting the bottom of the laptop's casing at a 45 degree angle, insert the casing's bottom "teeth" into their holders.
Place a bottom casing tooth into holder here
After the bottom of the casing is installed, apply slight pressure on the right, center, and left areas of the casing to place each tooth into its holder (see second photo).
Apply slight pressure on the right
Apply slight pressure on the center
Apply slight pressure on the left
You have now replaced your Gateway Z5WTC laptop hard drive! Thanks for reading.
