Gateway NV55S Screen Replacement
      • At both sides of the bottom of the screen, there are screw covers. Use a flathead screwdriver to remove them.
      • Behind each of them will be a screw. Unscrew each screw.
      Ask FixBot
    1. Gateway NV55S Screen Replacement, Remove LCD Bezel: step 2, image 1 of 1
      • Use a spudger to remove the bezel.
      Ask FixBot
    2. Gateway NV55S Screen Replacement, Remove lid: step 3, image 1 of 1
      • At each corner of the LCD will be one screw to remove. Remove each screw, disconnect the webcam (if applicable), and pull back on the lid.
      • Don't forget to disconnect the webcam before pulling the lid back!
      Ask FixBot
    3. Gateway NV55S Screen Replacement, Remove LCD cable: step 4, image 1 of 1
      • Separate all of the tape from the back of the LCD screen, and then pull straight back on the cable to remove it from the LCD.
      Ask FixBot
    4. Gateway NV55S Screen Replacement, Remove LCD: step 5, image 1 of 1
      • On each side of the LCD, there are three screws holding it. Remove all of them. You're done!
      Ask FixBot
Joseph Sctbunio
7,930 Reputation
42 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 96
All Time: 481
