Introduction
There will be prerequisites that you need to complete before displacing the motherboard. The prerequisites are available to you in the repair guide manual.
Turn the laptop on its backside with the stickers and barcode facing you.
Locate the latches on the top left corner.
Remove the five identical 3/16" Phillips #0 screws that secure the hard drive and memory cover.
Flip the device so the keyboard and display screen are faced upright.
Lift up the media button board cover using the heavy duty spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
Remove the 3/16" screw securing the motherboard with a Phillips #0 screwdriver.
when you are handling the motherboard you must observe electrostatic discharge precaution otherwise you will destroy the motherboard the author forgot to mention that do not attempt this repair without an anti-static wrist strap that must be tied into earth ground of a three-pronged electrical outlet
10 other people completed this guide.
8 Comments
Thanks so much for your guide post. I just finished replacing the CR2032 battery on my motherboard and could not have done it without your post.
larryrchrds whats symptoms did your Notebook have? Mine comes up with the charging light on, power light on but no display, no fan noise. if i connect the display to another screen nothing comes up either.The computer just stoped working out of the blue. Iam wondering if you experienced the same.
edson -
I had the same issue as edson. Replaced the CMOS and works fine now. Fantastic guide. I realise this is 3 years after the comment. But might be handy for anyone else with the same problem :)
Nice guide. Same symptoms!
What brand of motherboard am I looking for ??
I know this thread is YEARS OLD, but it’s one of the best disassembly guide out there for this old model! SUPER helpful!! Made all the difference in the world. THANK YOU for making it!
