Gateway MD2614u Processor (CPU) Replacement
  1. Gateway MD2614u Processor (CPU) Replacement, Back Cover: step 1, image 1 of 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor (CPU) Replacement: step 2, image 1 of 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor (CPU) Replacement: step 3, image 1 of 1
    • Lift off the cover.
  4. Gateway MD2614u Processor (CPU) Replacement, Fan: step 4, image 1 of 1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor (CPU) Replacement: step 5, image 1 of 1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor (CPU) Replacement: step 6, image 1 of 1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor (CPU) Replacement: step 7, image 1 of 1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor (CPU) Replacement, Processor (CPU): step 8, image 1 of 1
    • The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
    • You will hear a click as the lock unlocks.
  9. Gateway MD2614u Processor (CPU) Replacement: step 9, image 1 of 1
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
Toni Pipes
333 Reputation
7 Guides authored
Cal Poly, Team 21-31, Regan Fall 2010 Member of Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 7,172
