Gateway ID49C07U Battery Replacement
  1. Gateway ID49C07U Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Battery Replacement: step 2, image 1 of 2 Gateway ID49C07U Battery Replacement: step 2, image 2 of 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Battery Replacement: step 3, image 1 of 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Battery Replacement: step 4, image 1 of 1
    • While holding the release switch to the right, pull the battery away from you.
Patrick McGrail
445 Reputation
3 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 12
All Time: 355
