Installing Gateway 600YG2 LCD Display
  1. Installing Gateway 600YG2 LCD Display, Battery: step 1, image 1 of 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Installing Gateway 600YG2 LCD Display: step 2, image 1 of 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Installing Gateway 600YG2 LCD Display, Power Button Panel: step 3, image 1 of 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Installing Gateway 600YG2 LCD Display, LCD Display: step 4, image 1 of 1
    • Remove 5 screws.
    • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
    • Remove hinge covers.
  5. Installing Gateway 600YG2 LCD Display: step 5, image 1 of 1
    • Gently unplug LCD from system board.
  6. Installing Gateway 600YG2 LCD Display: step 6, image 1 of 1
    • Remove 6 screws holding LCD to hinge.
  7. Installing Gateway 600YG2 LCD Display: step 7, image 1 of 1
    • Pull LCD away from case.
Elizabeth Mazer
78 Reputation
10 Guides authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
22 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,886
