Up to 20% off select tools
Gatekeeper Wheel Tread Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
71
All Time:
788
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The tread may be damaged or severely worn when inspecting the security wheels on the Home Depot wire shopping carts. The Gatekeeper wheels are designed with replaceable tread.
    1. Gatekeeper Wheel Tread Replacement, Remove the Gatekeeper Wheel from the shopping cart.: step 1, image 1 of 1
      • Using two 7/16th box wrenches, loosen and remove the nut, washer and bolt. Set aside to reuse.
      Ask FixBot
    2. Gatekeeper Wheel Tread Replacement, Remove the damage/worn tread.: step 2, image 1 of 1
      • Using a T-15 Torx bit, remove the five screws, then pry the old tread off the wheel.
      Ask FixBot
    3. Gatekeeper Wheel Tread Replacement, Install new tread: step 3, image 1 of 1
      • Line up the new tread on the wheel, then insert five new screws using a T-15 Torx bit
      Ask FixBot
      • Replace the nut, washer and bolt that was removed in step 1
      Ask FixBot
Attached Documents
LANE
632 Reputation
2 Guides authored
The Home Depot Member of The Home Depot
Community
29,683 Members
864 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 71
All Time: 788
