Gas Grill Ceramic Briquettes Replacement
  1. Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: step 1, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: step 1, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: step 1, image 3 of 3
    • Carefully lift grill plate located above briquettes
  2. Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 3 of 3
    • Carefully remove entire ceramic briquette casing from above the stainless steel burner.
  3. Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: step 3, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: step 3, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: step 3, image 3 of 3
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
  4. Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: step 4, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: step 4, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: step 4, image 3 of 3
    • Using your hands, gently unscrew washers from the back of the casing.
    • A container is optional but recommended to hold the washers
  5. Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: step 5, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: step 5, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: step 5, image 3 of 3
    • Separate the front and back metal casings surrounding the briquettes.
  6. Gas Grill Ceramic Briquettes Replacement, Remove Old Briquettes: step 6, image 1 of 1
    • Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
  7. Gas Grill Ceramic Briquettes Replacement, Replace With New Ones: step 7, image 1 of 1
    • Take 16 new ceramic briquettes out and carefully align them inside of the casing. Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
emma
173 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 77
All Time: 3,588
