Introduction
This guide will be helpful if you are attempting to replace your nuviCam LMTHD battery. You might have a little trouble opening the device, but it does come off with a little force using the plastic prying tools. You might need to replace the battery if your device is not holding it's charge or the device is over heating. The battery is fairly simple to remove, good luck.
Disconnect the black and red wire from the screen.
Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
Is there a secret to reattaching the screen ribbon? Mine won’t go back in the slot.
7 other people completed this guide.
4 Comments
Where did you buy the battery? What is the voltage/current?
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
Hi Anybody Knows where I can buy the screen .
floresmorales063 - Reply
The screen Is impossible to find.
Robert - Reply
