This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Garmin Zumo 396 Power Button
    1. Garmin Zumo 396 Power Button, Power button: step 1, image 1 of 2 Garmin Zumo 396 Power Button, Power button: step 1, image 2 of 2
      • Cut a block 11 mm x 5.6 mm / 3 mm deep from a piece of hard rubber. I used a seal from a gas can (a door bumper also works)
      Ask FixBot
    2. Garmin Zumo 396 Power Button: step 2, image 1 of 2 Garmin Zumo 396 Power Button: step 2, image 2 of 2
      • Cut a piece out of an old bicycle inner tube and glue on the rubber block
      Ask FixBot
    3. Garmin Zumo 396 Power Button: step 3, image 1 of 1
      • trim the edges and test the fitment function in the Zumo
      Ask FixBot
    4. Garmin Zumo 396 Power Button: step 4, image 1 of 1
      • Then, apply adhesive to the rubber mat only along the outer bezel and, after curing, seal the edge again with adhesive (I used T-7000 adhesive).
      • The microswitch can now be actuated again by pressing on the center, and the Zumo 396 is protected against rain once more.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Ronny
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 10
All Time: 10
