Garmin Vívoactive 4 Watch Band Replacement
  1. Garmin Vívoactive 4 Watch Band Replacement, Watch Band: step 1, image 1 of 1
    • Flip the watch on its back to reveal the watch band connection pins.
  2. Garmin Vívoactive 4 Watch Band Replacement, Remove Bands: step 2, image 1 of 3 Garmin Vívoactive 4 Watch Band Replacement, Remove Bands: step 2, image 2 of 3 Garmin Vívoactive 4 Watch Band Replacement, Remove Bands: step 2, image 3 of 3
    • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
    • Push on the pin to release the strap from it's hinge.
    • Pull the strap away from the watch to disconnect it.
    • The strap will not pull away if the pin isn't fully pushed in.
  3. Garmin Vívoactive 4 Watch Band Replacement: step 3, image 1 of 1
    • With both straps removed, a new replacement watch band may be inserted.
Bryan Chavez
380 Reputation
4 Guides authored
UMass Dartmouth, Team 1-3, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-3, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G3
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 627
