At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Locate the battery bracket and two screws.
Use a Phillips #00 screwdriver to remove both of the screws.
Carefully peel the metal bracket away from the battery.
Pull the battery away from back cover.
Detach the wires from the speakers.
