Garmin Nuvi 255W Logic Board Replacement
  1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: step 1, image 1 of 2 Garmin Nuvi 255W Logic Board Replacement, Rear Casing: step 1, image 2 of 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 255W Logic Board Replacement: step 2, image 1 of 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 255W Logic Board Replacement: step 3, image 1 of 2 Garmin Nuvi 255W Logic Board Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 255W Logic Board Replacement, Logic Board: step 4, image 1 of 1
    • Pull out the cable between the logic board and the speaker to disconnect them.
  5. Garmin Nuvi 255W Logic Board Replacement: step 5, image 1 of 1
    • Peel away the material holding the ribbon cable in place.
  6. Garmin Nuvi 255W Logic Board Replacement: step 6, image 1 of 2 Garmin Nuvi 255W Logic Board Replacement: step 6, image 2 of 2
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 255W Logic Board Replacement: step 7, image 1 of 2 Garmin Nuvi 255W Logic Board Replacement: step 7, image 2 of 2
    • Detach the logic board form the battery by pulling out the cable.
Anjelica
564 Reputation
3 Guides authored
Cal Poly, Team 25-90, Amido Spring 2010 Member of Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Members
9 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 26
All Time: 10,396
