Introduction
The display assembly and front casing to the Garmin Nuvi 200W are exposed more than other internal elements of the device. Due to this vulnerable position, the casing may become scratched, damaged, or broken under stress. Replacing the rear casing can make the Nuvi 200W look new again, at much less cost!
It is important to note, however, that the case and it's internals require very specific screws, that are small and easy to lose. It is recommended that a magnet or tap is used to secure screws after removal. It is also important to gently remove the back casing, as it will be attached to other interior elements. This connection is sensitive and should be treated as such until the guide shows proper disconnection of this particular cable.
Only basic tools are required, such as screw drivers, and opening tools.
Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
Once you have a little gap, work it around the whole device with the tool to get separation.
Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
Slide the orange ribbon cable away from the ZIF connector.
