Garmin Nüvi 205W LCD Display Replacement
  1. Garmin Nüvi 205W LCD Display Replacement, LCD Display: step 1, image 1 of 3 Garmin Nüvi 205W LCD Display Replacement, LCD Display: step 1, image 2 of 3 Garmin Nüvi 205W LCD Display Replacement, LCD Display: step 1, image 3 of 3
    • The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • Remove the holder as well as the power cord from the back of the GPS unit.
    • The Nüvi uses two screws that are hidden underneath the label on the bottom.
  2. Garmin Nüvi 205W LCD Display Replacement: step 2, image 1 of 3 Garmin Nüvi 205W LCD Display Replacement: step 2, image 2 of 3 Garmin Nüvi 205W LCD Display Replacement: step 2, image 3 of 3
    • Remove the label, then remove the two Torx T5 screws
    • Use a plastic opening tool to start splitting the front and back case.
    • Work your way around the separation line, gently applying continous pressure to the back case.
  3. Garmin Nüvi 205W LCD Display Replacement: step 3, image 1 of 3 Garmin Nüvi 205W LCD Display Replacement: step 3, image 2 of 3 Garmin Nüvi 205W LCD Display Replacement: step 3, image 3 of 3
    • Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
    • The ribbon cable and connector are covered with a strip of Kapton tape
    • Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
  4. Garmin Nüvi 205W LCD Display Replacement: step 4, image 1 of 3 Garmin Nüvi 205W LCD Display Replacement: step 4, image 2 of 3 Garmin Nüvi 205W LCD Display Replacement: step 4, image 3 of 3
    • Once the tape is removed, flip the white clasp open, by moving it away from the cable end, disconnect the LCD.
    • Remove the On/Off switch
    • Remove the complete front assembly.
  5. Garmin Nüvi 205W LCD Display Replacement: step 5, image 1 of 3 Garmin Nüvi 205W LCD Display Replacement: step 5, image 2 of 3 Garmin Nüvi 205W LCD Display Replacement: step 5, image 3 of 3
    • The LCD assembly is held in the front bezel by seven plastic tabs.
    • Move those tabs slightly back while applying pressure from the opposite side (front of the LCD)
    • Continue to push the tabs on the bezel away from the LCD assembly, pushing the LCD away from the bezel
  6. Garmin Nüvi 205W LCD Display Replacement: step 6, image 1 of 3 Garmin Nüvi 205W LCD Display Replacement: step 6, image 2 of 3 Garmin Nüvi 205W LCD Display Replacement: step 6, image 3 of 3
    • Ensure that the LCD assembly clears all the tabs.
    • Remove the LCD from the front bezel
    • Totally separate the assembly from the bezel. Now it is time to replace it with a new assembly.
3 other people completed this guide.
oldturkey03
784,351 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
560 Guides authored
2 Comments
After reinstalling LCD screen how do I reconnect the ribbon cable? Any tips would be GREATLY appreciated :) Thank You
John - Reply
Thank you! Saved me a new GPS!
worthless0000 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 3,354
