Up to 20% off select tools
Garmin DriveSmart 71 EX Power Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
73
All Time:
245
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Over time, sediment and residue may build up inside the power button, preventing you from being able to turn on the device. If you replaced your battery and know that the battery is not damaged, and the device is still not turning on, you may need to replace your power button. This repair guide will teach you how to replace your power button.
    1. Garmin DriveSmart 71 EX Power Button Replacement, Case: step 1, image 1 of 1
      • Unplug and power off the device.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Power Button Replacement: step 2, image 1 of 1
      • Remove the four 5 mm T5 Torx screws securing the rear case.
      Ask FixBot
    3. Garmin DriveSmart 71 EX Power Button Replacement: step 3, image 1 of 3 Garmin DriveSmart 71 EX Power Button Replacement: step 3, image 2 of 3 Garmin DriveSmart 71 EX Power Button Replacement: step 3, image 3 of 3
      • Insert an opening pick into the seam between the front and back cover.
      • Carefully slide the opening pick around the perimeter of the device to release the clips securing the front and rear case.
      • Open the case with care not to strain the display ribbon cable or the microphone cable.
      • You may hear small snapping sounds as the clips release. Don't worry, this is normal.
      Ask FixBot
    1. Garmin DriveSmart 71 EX Power Button Replacement, Power Button: step 4, image 1 of 2 Garmin DriveSmart 71 EX Power Button Replacement, Power Button: step 4, image 2 of 2
      • Use tweezers to disconnect the battery and speaker connectors from their motherboard sockets.
      • Using tweezers is optional. If you remove the wires by hand, be careful not to damage them.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Power Button Replacement: step 5, image 1 of 1
      • Remove the four 4 mm screws securing the motherboard with a T5 Torx screwdriver.
      Ask FixBot
    3. Garmin DriveSmart 71 EX Power Button Replacement: step 6, image 1 of 3 Garmin DriveSmart 71 EX Power Button Replacement: step 6, image 2 of 3 Garmin DriveSmart 71 EX Power Button Replacement: step 6, image 3 of 3
      • Lift up the motherboard to expose the power button. Take care not to strain the connected ribbon cable.
      • Remove the power button.
      Ask FixBot
Author
with
Brooke Wood
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 73
All Time: 245
