Garmin DriveSmart 50 LMTHD Display Replacement
    1. Garmin DriveSmart 50 LMTHD Display Replacement, Display: step 1, image 1 of 1
      • Remove the four 5 mm screws from the back of the device using a T4 Torx screwdriver.
      Ask FixBot
    2. Garmin DriveSmart 50 LMTHD Display Replacement: step 2, image 1 of 2 Garmin DriveSmart 50 LMTHD Display Replacement: step 2, image 2 of 2
      • Use a spudger to gently pry the locks around the screen, applying even pressure along the edges.
      Ask FixBot
    3. Garmin DriveSmart 50 LMTHD Display Replacement: step 3, image 1 of 2 Garmin DriveSmart 50 LMTHD Display Replacement: step 3, image 2 of 2
      • Carefully open the casing to avoid damaging any fragile components, and gently disconnect the black and red wire plug attached to it.
      • Since the plug is on a hook, unlock it with the spudger tool.
      Ask FixBot
    4. Garmin DriveSmart 50 LMTHD Display Replacement: step 4, image 1 of 2 Garmin DriveSmart 50 LMTHD Display Replacement: step 4, image 2 of 2
      • Flip the Garmin over to the other side in the previous step, and slide the screen backwards to undo the orange connector.
      • Use the pointed end of the spudger tool to lift the clasps and detach the orange connector.
      Ask FixBot
    5. Garmin DriveSmart 50 LMTHD Display Replacement: step 5, image 1 of 1
      • Gently lift the screen case from the back mount.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 69
All Time: 350
