Garmin Drive 53 EX Battery Replacement
  1. Garmin Drive 53 EX Battery Replacement, Display: step 1, image 1 of 2 Garmin Drive 53 EX Battery Replacement, Display: step 1, image 2 of 2
    • Power off the Garmin Drive 53 EX completely to prevent electrical shorts during the repair.
    • Use a T2 Torx screwdriver to remove all four screws.
    Ask FixBot
  2. Garmin Drive 53 EX Battery Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool or a thin prying pick into the seam where the front bezel meets the rear housing.
    • Gently lift the rear casing away from the front assembly, being careful not to strain the internal ribbon cable connecting the screen to the motherboard.
    Ask FixBot
  3. Garmin Drive 53 EX Battery Replacement: step 3, image 1 of 1
    • Open the ZIF (Zero Insertion Force) connector on the motherboard by flipping up the small locking tab and sliding the screen’s ribbon cable out.
    • Remove the screen.
    Ask FixBot
  4. Garmin Drive 53 EX Battery Replacement, Battery: step 4, image 1 of 1
    • Insert an opening tool underneath the battery.
    • Slowly and carefully, raise the battery to remove it from the device.
    Ask FixBot
  5. Garmin Drive 53 EX Battery Replacement: step 5, image 1 of 1
    • Carefully disconnect the wire connecting the battery to the motherboard.
    Ask FixBot
  6. Garmin Drive 53 EX Battery Replacement: step 6, image 1 of 1
    • Remove the battery from the device.
    Ask FixBot
Prabhav Kuruva
553 Reputation
4 Guides authored
Texas Tech, Team 16-3, Samson Spring 2026 Member of Texas Tech, Team 16-3, Samson Spring 2026
TTU-SAMSON-S26S16G3
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 47
All Time: 112
