Garmin Drive 50 LM Power Button Replacement
    1. Garmin Drive 50 LM Power Button Replacement, Garmin Drive 50 LM Case Removal: step 1, image 1 of 3 Garmin Drive 50 LM Power Button Replacement, Garmin Drive 50 LM Case Removal: step 1, image 2 of 3 Garmin Drive 50 LM Power Button Replacement, Garmin Drive 50 LM Case Removal: step 1, image 3 of 3
      • Use a T5 Torx screwdriver to remove the four 9 mm-long screws securing the case.
      Ask FixBot
    2. Garmin Drive 50 LM Power Button Replacement: step 2, image 1 of 2 Garmin Drive 50 LM Power Button Replacement: step 2, image 2 of 2
      • Insert an opening tool into the seam between the case and the chassis.
      • Pry around the perimeter of the device until the case releases.
      • It is recommended to work along the length of the device first, then the width.
      Ask FixBot
    3. Garmin Drive 50 LM Power Button Replacement: step 3, image 1 of 1
      • Once open, set the screen down at an offset to be able to see the yellow cable.
      Ask FixBot
    4. Garmin Drive 50 LM Power Button Replacement: step 4, image 1 of 3 Garmin Drive 50 LM Power Button Replacement: step 4, image 2 of 3 Garmin Drive 50 LM Power Button Replacement: step 4, image 3 of 3
      • With tweezers, flip up the brown locking flap to release the ribbon cable.
      • Gently disconnect the yellow ribbon cable.
      Ask FixBot
    1. Garmin Drive 50 LM Power Button Replacement, Motherboard: step 5, image 1 of 3 Garmin Drive 50 LM Power Button Replacement, Motherboard: step 5, image 2 of 3 Garmin Drive 50 LM Power Button Replacement, Motherboard: step 5, image 3 of 3
      • With tweezers, unplug the battery (red cord) from the motherboard.
      • Do the same for the speaker (blue cord).
      • Gently move both cords out of the way of the mother board, if needed, fully remove the speaker and battery by gently pulling them out of the case.
      Ask FixBot
    2. Garmin Drive 50 LM Power Button Replacement: step 6, image 1 of 3 Garmin Drive 50 LM Power Button Replacement: step 6, image 2 of 3 Garmin Drive 50 LM Power Button Replacement: step 6, image 3 of 3
      • With a T5 Torx screwdriver, remove the four 5 mm-long screws from the corners of the motherboard that is attached to the back of the case.
      Ask FixBot
    3. Garmin Drive 50 LM Power Button Replacement: step 7, image 1 of 3 Garmin Drive 50 LM Power Button Replacement: step 7, image 2 of 3 Garmin Drive 50 LM Power Button Replacement: step 7, image 3 of 3
      • Gently remove the motherboard from the case.
      Ask FixBot
    1. Garmin Drive 50 LM Power Button Replacement, Power Button: step 8, image 1 of 3 Garmin Drive 50 LM Power Button Replacement, Power Button: step 8, image 2 of 3 Garmin Drive 50 LM Power Button Replacement, Power Button: step 8, image 3 of 3
      • With tweezers, pickup the button from this latch to the side, gently pull upwards until it is dislodged.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 49
All Time: 183
