Garmin Drive 50 LM Case Removal
    1. Garmin Drive 50 LM Case Removal, Garmin Drive 50 LM Case Removal: step 1, image 1 of 3 Garmin Drive 50 LM Case Removal, Garmin Drive 50 LM Case Removal: step 1, image 2 of 3 Garmin Drive 50 LM Case Removal, Garmin Drive 50 LM Case Removal: step 1, image 3 of 3
      • Use a T5 Torx screwdriver to remove the four 9 mm-long screws securing the case.
      Ask FixBot
    2. Garmin Drive 50 LM Case Removal: step 2, image 1 of 2 Garmin Drive 50 LM Case Removal: step 2, image 2 of 2
      • Insert an opening tool into the seam between the case and the chassis.
      • Pry around the perimeter of the device until the case releases.
      • It is recommended to work along the length of the device first, then the width.
      Ask FixBot
    3. Garmin Drive 50 LM Case Removal: step 3, image 1 of 1
      • Once open, set the screen down at an offset to be able to see the yellow cable.
      Ask FixBot
    4. Garmin Drive 50 LM Case Removal: step 4, image 1 of 3 Garmin Drive 50 LM Case Removal: step 4, image 2 of 3 Garmin Drive 50 LM Case Removal: step 4, image 3 of 3
      • With tweezers, flip up the brown locking flap to release the ribbon cable.
      • Gently disconnect the yellow ribbon cable.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 51
All Time: 217
