Shop the Holiday Gift Guide
GameStop GS3 GameCube Controller Disassembly
View statistics:
Past 24 Hours:
6
Past 7 Days:
15
Past 30 Days:
67
All Time:
867
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Tools
    1. GameStop GS3 GameCube Controller Disassembly, Remove four screws on the back of the unit: step 1, image 1 of 2 GameStop GS3 GameCube Controller Disassembly, Remove four screws on the back of the unit: step 1, image 2 of 2
      • Turn the controller over so the back is facing upwards.
      Ask FixBot
    2. GameStop GS3 GameCube Controller Disassembly: step 2, image 1 of 3 GameStop GS3 GameCube Controller Disassembly: step 2, image 2 of 3 GameStop GS3 GameCube Controller Disassembly: step 2, image 3 of 3
      • Carefully pry open the controller. Ensure that the rumble assembly stays intact.
      Ask FixBot
    3. GameStop GS3 GameCube Controller Disassembly: step 3, image 1 of 2 GameStop GS3 GameCube Controller Disassembly: step 3, image 2 of 2
      • Locate the two black screws attached to the rumble assembly. Remove them and separate the motor from the back casing.
      Ask FixBot
    4. GameStop GS3 GameCube Controller Disassembly: step 4, image 1 of 3 GameStop GS3 GameCube Controller Disassembly: step 4, image 2 of 3 GameStop GS3 GameCube Controller Disassembly: step 4, image 3 of 3
      • Locate the green pcb on the main assembly. Remove the silver screw on the green pcb to separate it from the controller casing.
      Ask FixBot
    5. GameStop GS3 GameCube Controller Disassembly: step 5, image 1 of 2 GameStop GS3 GameCube Controller Disassembly: step 5, image 2 of 2
      • Locate the two silver screws on the brown pcb. Remove them and carefully pry both pcbs off of the controller casing. Ensure that the buttons on the controller casing remain in place.
      Ask FixBot
    6. GameStop GS3 GameCube Controller Disassembly: step 6, image 1 of 2 GameStop GS3 GameCube Controller Disassembly: step 6, image 2 of 2
      • Firmly pry the plastic part of the problematic joystick off of the pcb. Take care to ensure that the pcb remains intact.
      Ask FixBot
    7. GameStop GS3 GameCube Controller Disassembly: step 7, image 1 of 1
      • Examine the joystick module on the pcb. Stick drift is a common problem and is usually caused by dirt and debris inside the metal casing. Use rubbing alcohol and a tissue to clean the affected area.
      Ask FixBot
Author
with
Brandon
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 67
All Time: 867
