GameSir X2s Type-C Left Trigger Replacement
    1. GameSir X2s Type-C Left Trigger Replacement, Back: step 1, image 1 of 2 GameSir X2s Type-C Left Trigger Replacement, Back: step 1, image 2 of 2
      • Use a 000 Phillips screwdriver to remove the following eight silver fine-thread 6mm screws.
      • Flip the controller upright.
      Ask FixBot
    2. GameSir X2s Type-C Left Trigger Replacement: step 2, image 1 of 3 GameSir X2s Type-C Left Trigger Replacement: step 2, image 2 of 3 GameSir X2s Type-C Left Trigger Replacement: step 2, image 3 of 3
      • Remove the four silver fine-thread 4.5mm screws under the rubber grip using the 000 Phillips screwdriver.
      • Flip the GameSir X2s Type-C to the back.
      • Using a prying tool around the lip, where both pieces of plastic meet, run that around the hold device.
      • Pop off the plastic piece attached to the device.
      Ask FixBot
    3. GameSir X2s Type-C Left Trigger Replacement: step 3, image 1 of 3 GameSir X2s Type-C Left Trigger Replacement: step 3, image 2 of 3 GameSir X2s Type-C Left Trigger Replacement: step 3, image 3 of 3
      • Remove the blue strip connected to the board.
      • Remove six silver fine-thread 4.5mm screws and the two black fine-thread 4.5mm screws using a 000 Phillips screwdriver.
      • Remove the gold strip connected to the board.
      Ask FixBot
    4. GameSir X2s Type-C Left Trigger Replacement: step 4, image 1 of 3 GameSir X2s Type-C Left Trigger Replacement: step 4, image 2 of 3 GameSir X2s Type-C Left Trigger Replacement: step 4, image 3 of 3
      • Remove the three black fine-thread 4.5mm screws using the 000 Phillips screwdriver.
      • Remove the red and black wires from the board.
      • Remove the board from the GameSir X2s Type-C.
      Ask FixBot
    5. GameSir X2s Type-C Left Trigger Replacement: step 5, image 1 of 3 GameSir X2s Type-C Left Trigger Replacement: step 5, image 2 of 3 GameSir X2s Type-C Left Trigger Replacement: step 5, image 3 of 3
      • Remove the 3 black fine-thread 4.5mm screws from behind the right trigger using a 000 Phillips screwdriver.
      • Remove the 3 black fine-thread 4.5mm screws from the board using a 000 Phillips screwdriver.
      Ask FixBot
    6. GameSir X2s Type-C Left Trigger Replacement: step 6, image 1 of 1
      • Remove the black electrical board from the GameSir X2s Type-C.
      Ask FixBot
    1. GameSir X2s Type-C Left Trigger Replacement, Left Trigger: step 7, image 1 of 2 GameSir X2s Type-C Left Trigger Replacement, Left Trigger: step 7, image 2 of 2
      • Remove the four black fine-threaded black 4.5mm screws with 000 Phillips screwdriver.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 50
All Time: 232
