GameSir T4 Pro Directional Pad Replacement
  1. GameSir T4 Pro Directional Pad Replacement, Battery: step 1, image 1 of 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Directional Pad Replacement: step 2, image 1 of 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Directional Pad Replacement: step 3, image 1 of 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Directional Pad Replacement: step 4, image 1 of 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Directional Pad Replacement, Directional Pad: step 5, image 1 of 2 GameSir T4 Pro Directional Pad Replacement, Directional Pad: step 5, image 2 of 2
    • To get to the directional pad (d-pad), remove the three 5mm screws on the motherboard.
  6. GameSir T4 Pro Directional Pad Replacement: step 6, image 1 of 1
    • Disconnect all white connectors from the motherboard.
  7. GameSir T4 Pro Directional Pad Replacement: step 7, image 1 of 1
    • Carefully pull the motherboard away to reveal the front panel.
  8. GameSir T4 Pro Directional Pad Replacement: step 8, image 1 of 1
    • Remove the d-pad from the front panel.
  9. GameSir T4 Pro Directional Pad Replacement: step 9, image 1 of 1
    • Place your new d-pad in place.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 39
All Time: 1,305
