GameSir T4 Pro Battery Replacement
    1. GameSir T4 Pro Battery Replacement, Battery: step 1, image 1 of 1
      • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
      Ask FixBot
    2. GameSir T4 Pro Battery Replacement: step 2, image 1 of 1
      • Use your iFixit opening tool to break the seam of the back of your controller.
      • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
      Ask FixBot
    3. GameSir T4 Pro Battery Replacement: step 3, image 1 of 1
      • Using the plastic spudger, wiggle the connection out of place.
      Ask FixBot
    4. GameSir T4 Pro Battery Replacement: step 4, image 1 of 1
      • Apply a slow, but consistent pull to the old 600 maH battery.
      • Attach new battery onto the pad.
      Ask FixBot
3 other people completed this guide.
3 Guide Comments
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - Reply Share
Where can I buy this battery? Do You have a link to it?
Roberto Barros - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 144
All Time: 5,053
