GameSir Cyclone 2 Face Plate Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
44
Past 30 Days:
159
All Time:
949
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Follow this guide to remove the face plate (also called front plate or top cover) of your GameSir Cyclone 2 controller. This is useful if you need to replace the face plate or access the internal components of your controller.
Tools
    1. GameSir Cyclone 2 Face Plate Replacement, Face Plate: step 1, image 1 of 3 GameSir Cyclone 2 Face Plate Replacement, Face Plate: step 1, image 2 of 3 GameSir Cyclone 2 Face Plate Replacement, Face Plate: step 1, image 3 of 3
      • Flip the controller around so the back part is facing you.
      • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
      • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
      Ask FixBot
    2. GameSir Cyclone 2 Face Plate Replacement: step 2, image 1 of 1
      • The screws holding the face plate are of two different lengths:
      • The two longer screws belong to the two top screw sockets on the controller.
      • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
      Ask FixBot
    3. GameSir Cyclone 2 Face Plate Replacement: step 3, image 1 of 2 GameSir Cyclone 2 Face Plate Replacement: step 3, image 2 of 2
      • Face the controller toward you.
      • Gently lift the face plate off the controller.
      • The d-pad and action buttons will become loose once the face plate is lifted.
      Ask FixBot
2 other people completed this guide.
Ross Debortoli
334 Reputation
3 Guides authored
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 159
All Time: 949
