Game Boy Cartridge Battery Replacement
    1. Game Boy Cartridge Battery Replacement, Battery: step 1, image 1 of 2 Game Boy Cartridge Battery Replacement, Battery: step 1, image 2 of 2
      • Use the screwdriver to loosen the screw on the cartridge.
      Ask FixBot
    2. Game Boy Cartridge Battery Replacement: step 2, image 1 of 1
      • Switch on your multimeter and select the Voltage (V) mode. Then, test the voltage of the battery in the cartridge.
      Ask FixBot
    3. Game Boy Cartridge Battery Replacement: step 3, image 1 of 1
      • Apply some of the flux paste to help desolder the soldered areas on the battery.
      Ask FixBot
    4. Game Boy Cartridge Battery Replacement: step 4, image 1 of 1
      • Be careful when handling a fully heated soldering iron, as it can burn you.
      • Use the soldering iron once it heats up fully. Then, heat up the soldered areas with the iron.
      Ask FixBot
    5. Game Boy Cartridge Battery Replacement: step 5, image 1 of 2 Game Boy Cartridge Battery Replacement: step 5, image 2 of 2
      • Pick up the solder with the desoldering braid.
      Ask FixBot
    6. Game Boy Cartridge Battery Replacement: step 6, image 1 of 1
      • Wipe off any excess flux paste.
      • The flux paste can damage the circuit board if not removed completely or spread to other areas on the circuit board.
      Ask FixBot
    7. Game Boy Cartridge Battery Replacement: step 7, image 1 of 2 Game Boy Cartridge Battery Replacement: step 7, image 2 of 2
      • Make sure to align the battery's positive side where the positive indicator is and the negative side where the negative indicator is.
      • Use the soldering iron and soldering wire to solder both sides of the battery into place.
      Ask FixBot
    8. Game Boy Cartridge Battery Replacement: step 8, image 1 of 1
      • The battery has to have at least 1.5V. If the multimeter reads a negative value, then most likely, the terminals are placed opposite, so switch them around and check the resulting value once more.
      Ask FixBot
    9. Game Boy Cartridge Battery Replacement: step 9, image 1 of 2 Game Boy Cartridge Battery Replacement: step 9, image 2 of 2
      • Align the cartridge and the circuit board.
      • Then tighten the screw to secure the cartridge into place.
      Ask FixBot
To reassemble your game cartridge, follow step 9.
10 other people completed this guide.
Jose Ayala
533 Reputation
1 Guide authored
1 Guide Comment
Hi, I think the CR2032 is to big. On the cartridge PCB is written: CR1616. I think this is the correct battery. But I have one unofficial gameboy cartridge, which use a CR2032, but for original cartridges it is too big.
Keywan - Reply Share
Past 24 Hours: 20
Past 7 Days: 137
Past 30 Days: 632
All Time: 14,112
