Game Boy Pocket Buttons Replacement
  1. Game Boy Pocket Buttons Replacement, Buttons: step 1, image 1 of 3 Game Boy Pocket Buttons Replacement, Buttons: step 1, image 2 of 3 Game Boy Pocket Buttons Replacement, Buttons: step 1, image 3 of 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Buttons Replacement: step 2, image 1 of 3 Game Boy Pocket Buttons Replacement: step 2, image 2 of 3 Game Boy Pocket Buttons Replacement: step 2, image 3 of 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Buttons Replacement: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the three screws from the motherboard.
  4. Game Boy Pocket Buttons Replacement: step 4, image 1 of 3 Game Boy Pocket Buttons Replacement: step 4, image 2 of 3 Game Boy Pocket Buttons Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Buttons Replacement: step 5, image 1 of 2 Game Boy Pocket Buttons Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Buttons Replacement: step 6, image 1 of 3 Game Boy Pocket Buttons Replacement: step 6, image 2 of 3 Game Boy Pocket Buttons Replacement: step 6, image 3 of 3
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket Buttons Replacement: step 7, image 1 of 3 Game Boy Pocket Buttons Replacement: step 7, image 2 of 3 Game Boy Pocket Buttons Replacement: step 7, image 3 of 3
    • Use your fingers to remove the three silicone button covers.
    • Use a plastic opening tool to remove the buttons.
3 other people completed this guide.
Adriana Rahrig
1,523 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2014 Member of USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Members
18 Guides authored
One Comment
where can you just buy the a and b buttons (if possible)
Eian Anderson - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 47
All Time: 4,545
