Installing Game Boy Advance Buttons
  1. Installing Game Boy Advance Buttons, Remove the Battery Cover/Batteries: step 1, image 1 of 3 Installing Game Boy Advance Buttons, Remove the Battery Cover/Batteries: step 1, image 2 of 3 Installing Game Boy Advance Buttons, Remove the Battery Cover/Batteries: step 1, image 3 of 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Installing Game Boy Advance Buttons, Unscrew the Back Panel: step 2, image 1 of 2 Installing Game Boy Advance Buttons, Unscrew the Back Panel: step 2, image 2 of 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Installing Game Boy Advance Buttons, Remove the Back Panel: step 3, image 1 of 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Installing Game Boy Advance Buttons, Remove Triggers: step 4, image 1 of 2 Installing Game Boy Advance Buttons, Remove Triggers: step 4, image 2 of 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  5. Installing Game Boy Advance Buttons, Remove the On/Off Switch: step 5, image 1 of 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Installing Game Boy Advance Buttons, Buttons and LCD Screen: step 6, image 1 of 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  7. Installing Game Boy Advance Buttons: step 7, image 1 of 2 Installing Game Boy Advance Buttons: step 7, image 2 of 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
  8. Installing Game Boy Advance Buttons, Buttons: step 8, image 1 of 3 Installing Game Boy Advance Buttons, Buttons: step 8, image 2 of 3 Installing Game Boy Advance Buttons, Buttons: step 8, image 3 of 3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
Ben
530 Reputation
1 Guide authored
Cal Poly, Team 16-29, Maness Winter 2010 Member of Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Members
61 Guides authored
Past 24 Hours: 7
Past 7 Days: 51
Past 30 Days: 327
All Time: 23,633
