Shop the Holiday Gift Guide
GPU Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
38
Past 30 Days:
112
All Time:
3,270
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
GPU Replacement
Introduction
Go to step 1 ↓
This guide details the replacement of a graphics processing unit using the B350M BAZOOKA Motherboard. This guide requires no prior knowledge or special skills to complete. However, there are a few things to be cautious of:
  • The possibility of shattering a glass front panel.
  • The possibility of static build-up.
  • Turn off the desktop before starting, and handle all parts with care.
Tools
    1. GPU Replacement, Graphics Processing Unit: step 1, image 1 of 1
      • Establish a clean work space.
      Ask FixBot
    2. GPU Replacement: step 2, image 1 of 3 GPU Replacement: step 2, image 2 of 3 GPU Replacement: step 2, image 3 of 3
      • Turn the desktop's power supply off.
      • Unplug the desktop from all power sources.
      Ask FixBot
    3. GPU Replacement: step 3, image 1 of 2 GPU Replacement: step 3, image 2 of 2
      • Remove the screws on the side of the case.
      • Screw types may vary by desktop case.
      • These screws hold the side panel, which promotes airflow inside the desktop. Do not misplace them.
      Ask FixBot
    4. GPU Replacement: step 4, image 1 of 2 GPU Replacement: step 4, image 2 of 2
      • Gently remove the side panel by pulling it away from the case.
      Ask FixBot
    5. GPU Replacement: step 5, image 1 of 1
      • Place the desktop horizontally, so the motherboard is facing up.
      Ask FixBot
    6. GPU Replacement: step 6, image 1 of 3 GPU Replacement: step 6, image 2 of 3 GPU Replacement: step 6, image 3 of 3
      • Disconnect the 8-pin PCI-E cable from the GPU.
      Ask FixBot
    7. GPU Replacement: step 7, image 1 of 2 GPU Replacement: step 7, image 2 of 2
      • Remove the UTS 6-32 screws on the side of the desktop using a Phillips #0 or a flathead screwdriver.
      • These screws hold the GPU in place. Do not misplace them.
      Ask FixBot
    8. GPU Replacement: step 8, image 1 of 2 GPU Replacement: step 8, image 2 of 2
      • Gently press down on the right side of the PCI-E tab until there is a click.
      • The click signifies the GPU has been released.
      Ask FixBot
    9. GPU Replacement: step 9, image 1 of 1
      • Gently pull the GPU out of the PCI-E slot.
      Ask FixBot
    10. GPU Replacement: step 10, image 1 of 3 GPU Replacement: step 10, image 2 of 3 GPU Replacement: step 10, image 3 of 3
      • Line up the pins of the new GPU with the empty PCI-E slot.
      • Gently push the new GPU into the PCI-E slot until the tab clicks.
      Ask FixBot
    11. GPU Replacement: step 11, image 1 of 3 GPU Replacement: step 11, image 2 of 3 GPU Replacement: step 11, image 3 of 3
      • Gently connect the 8-pin PCI-E cable from the power supply to the new GPU.
      Ask FixBot
    12. GPU Replacement: step 12, image 1 of 2 GPU Replacement: step 12, image 2 of 2
      • Screw the UTS 6-32 screws which hold the GPU in place back in using a Phillips #0 screwdriver.
      Ask FixBot
    13. GPU Replacement: step 13, image 1 of 1
      • Gently place the side panel back on the case.
      Ask FixBot
    14. GPU Replacement: step 14, image 1 of 3 GPU Replacement: step 14, image 2 of 3 GPU Replacement: step 14, image 3 of 3
      • Screw in the side panel screws.
      Ask FixBot
    15. GPU Replacement: step 15, image 1 of 3 GPU Replacement: step 15, image 2 of 3 GPU Replacement: step 15, image 3 of 3
      • Plug the desktop back into a power source.
      • Turn the desktop's power supply on.
      • If the fans on the bottom of the GPU are not spinning once the desktop is on, retry this process. Or begin troubleshooting for a defective GPU.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Mason Price
319 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 112
All Time: 3,270
