Up to 20% off select tools
GE Washing Machine Agitator Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
22
Past 7 Days:
152
Past 30 Days:
623
All Time:
2,813
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Video Guide
This guide was transcribed from a YouTube video.
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide when the agitator in your GE top-load washer is damaged or when you must remove it to reach the hub or the 7⁄16-inch transmission bolt hidden underneath. The procedure relies on a hidden alignment hole and takes only basic hand tools once you know the trick.
      • Raise the lid to give full access to the agitator assembly.
      Ask FixBot
      • Look for the small round hole located at the very bottom of the agitator skirt.
      • This hole is the only place where a tool can lock the agitator for removal.
      Ask FixBot
      • Feel around the agitator base until you find the raised nipple on the washer plate.
      • Rotate the agitator until its hole lines up directly over the nipple.
      • Removal will not work unless these two features line up exactly.
      Ask FixBot
      • Insert a Phillips screwdriver through the hole and press it in until it bottoms out.
      • Push the screwdriver in deeply so it fully engages the mechanism.
      Ask FixBot
      • Have a helper hold the washer tub steady so it cannot rotate while you twist the agitator.
      • If working solo, brace the tub with your free hand while keeping the screwdriver seated.
      Ask FixBot
      • Grip the agitator housing and turn it clockwise until it breaks free from the drive tabs.
      • Lift the agitator straight up and out of the tub once it releases.
      Ask FixBot
      • If you need hub access, remove the central 7⁄16-inch bolt with a socket wrench and lift off the plate.
      Ask FixBot
      • Align the four slots on the agitator base with the four plastic retention pieces on the washer plate.
      • Lower the agitator onto the tabs until it sits flush on the plate.
      Ask FixBot
      • Twist the agitator clockwise until it snaps and will not rotate freely.
      • Rock the agitator back and forth to confirm it is fully seated.
      Ask FixBot
      • Press the fabric-softener dispenser cap back onto the agitator top.
      Ask FixBot
Repair didn't go as planned? Ask our Answers community for help.
Author
with
Ben Schlichter
7,269 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 22
Past 7 Days: 152
Past 30 Days: 623
All Time: 2,813
