GE Top Load Washing Machine Control Board Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
10
Past 7 Days:
67
Past 30 Days:
275
All Time:
1,456
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to replace and program the main control board in your GE top-load washing machine. A failed control board can cause the washer to not start, especially after other likely causes (like a harness issue) have been ruled out. Many GE top-load washers share the same board hardware across multiple models, so the replacement board must be programmed (set to the correct “personality”) for the exact washer model, or features may not work.
Common compatible board families that require programming include GE WH22X38441, GE WH22X38442, and GE WH22X38438.
      • Unplug the washing machine.
      • Shut off the water supplies if the washer must be moved far enough to strain the hoses.
      • Move the washer so you can access the rear of the console.
      • Handle the control board by its edges and avoid touching components more than necessary.
      Ask FixBot
      • Use a 1/4-inch hex head screwdriver to remove the two long vertical screws at the rear of the console.
      • These screws are very long, so expect them to take a bit of time to fully unthread.
      Ask FixBot
      • Push the console rearward by pressing or striking the console sides with a fist to release it.
      • Pivot the console up and away from the washer.
      • Disconnect the pressure hose from the console area if it prevents the console from opening far enough.
      Ask FixBot
      • Slide the rear console panel from left to right to release it.
      • Lift the panel away from the console to improve access to the control board.
      Ask FixBot
      • Take a photo of all wire and connector locations on the control board.
      • Disconnect all wiring harness connectors from the control board.
      • Most connectors are color-coded and keyed, so they only fit one location and direction.
      Ask FixBot
      • Use a 1/4-inch hex head screwdriver to remove the four shallow screws from the plastic retaining cover.
      • Press the plastic tab on the upper corner of the board area to release the cover.
      • Lift the retaining cover off the control board.
      Ask FixBot
      • Pull the central control dial straight off the front of the console.
      • Lift the control board out of the console.
      • If the Start/Pause or Deep Fill button caps shift during removal, reseat them before installing the new board.
      Ask FixBot
      • Set the new control board into the console and align it with the control knob hole.
      • Align the board with the four mounting posts used by the retaining cover screws.
      • Expect the replacement board to look different than the old one, because GE uses multiple board revisions.
      • Reinstall the plastic retaining cover, seating the upper corner post first so it snaps into place.
      • Use a 1/4-inch hex head screwdriver to install the four retaining cover screws.
      Ask FixBot
      • Press the control dial onto the new board shaft, aligning the flat on the knob with the flat on the shaft.
      • Reconnect all wiring harness connectors to the control board.
      • Reconnect the gray pressure hose to the sensor connection.
      • If the replacement board has an extra unused port for other models, leave it disconnected.
      Ask FixBot
      • Slot the console into the washer top, making sure the console posts on both sides seat into the washer top.
      • Leave the rear panel and rear console screws off if you want to test programming before fully reassembling.
      Ask FixBot
      • Move the washer to an outlet and plug it in.
      • Wait for the console lights to flash, indicating the washer is ready to be programmed.
      Ask FixBot
      • Find the washer model number on the model tag by raising the lid.
      • Use the programming instructions for the exact control board model to find the matching personality for the washer model.
      • Some OEM boards include a card with instructions for requesting the programming document using the board part number.
      • If instructions won’t return when using a part number ending in a letter, try entering the part number without the trailing letter.
      Ask FixBot
      • Press the Start/Pause button repeatedly until the console light pattern matches the correct personality for the washer model.
      • If the correct personality is listed as no lights illuminated, don’t change anything.
      • Press and hold the Start/Pause button for 3 to 5 seconds to save the selection.
      • Confirm programming by checking that all lights turn off.
      Ask FixBot
      • Unplug the washer, then plug it back in to start fresh.
      • Press and hold the Start button, rotate the control dial about 180° counterclockwise, and then release the Start button.
      • Count about seven or eight clicks while rotating the dial, and don’t worry if you go a little past 180°.
      • Confirm diagnostic mode by checking for relay clicking and flashing lights.
      • Rotate the dial clockwise twice until the Rinse light is illuminated, then press Start to enable personality selection.
      • Rotate the dial to cycle through light combinations until the pattern matches the correct personality for the washer model.
      • Press and hold the Start button for 3 to 5 seconds to save the selection, and confirm that all lights turn off.
      Ask FixBot
If the new board powers up and the washer accepts the correct personality setting, the replacement is complete. Recheck every connector and confirm the programming steps were followed exactly if the machine stays unresponsive or the board will not configure. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,152 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 67
Past 30 Days: 275
All Time: 1,456
