GE Front-Load Washing Machine Damper Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
142
All Time:
852
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
A GE front-load washer that powers up but will not begin a cycle can have a failed blue damper vent. This component opens to keep the tub fresh between loads, and the control will cancel a wash if the damper cannot move. Use this guide to confirm the failure with a multimeter, replace the old damper, and reassemble the machine.
Parts
Tools
      • Press and hold the Start ⁄ Pause button for eight seconds to enter service mode.
      • Tap the same button once to display stored error numbers.
      • Scroll through the stored codes and look for any damper-related faults.
      • If a damper code appears, continue with electrical testing before parts replacement.
      Ask FixBot
      • Unplug the washer and close the water supply valves before opening the cabinet.
      • Have a Phillips screwdriver and a multimeter equipped with thin probe tips on hand.
      • Put on cut-resistant gloves to protect hands while handling sharp metal and the door gasket.
      Ask FixBot
      • Pull the detergent drawer out, press the rear release tab, and fully remove the drawer.
      • Take out five Phillips screws inside the dispenser recess, noting that the two center screws have a different thread than the outer three.
      • Lift the left side of the control interface about 20 degrees, slide it right, and pull it forward while supporting the attached wiring.
      Ask FixBot
      • Undo the three Phillips screws securing the rear edge of the top panel.
      • Slide the panel toward you and lift it off to expose the main control area.
      Ask FixBot
      • Remove one screw from the plastic shield and two screws from the metal cover.
      • Slide the metal cover forward to release it, then take out the final screw hidden underneath.
      Ask FixBot
      • Press the locking tabs and move the wire trunks away from the board for better probe access.
      Ask FixBot
      • Locate the blue three-wire harness in the center of the board and disconnect it by squeezing its latch.
      • Set the multimeter to 2 kΩ–20 kΩ or auto-range resistance mode.
      • Probe middle-to-left and middle-to-right pins; a healthy damper measures about 4.2 kΩ on each reading.
      • An open circuit or a value far from 4.2 kΩ indicates a failed damper or damaged wiring.
      • If readings are correct yet the fault persists, the control board may not be sending voltage to the damper.
      Ask FixBot
      • Insert a pick or small screwdriver at the 6 o’clock position, pry the spring clamp out of the groove, and peel the outer lip of the gasket off the front panel.
      Ask FixBot
      • Remove the three Phillips screws securing the damper assembly to the bulkhead.
      • Push the assembly rearward and then downward to disengage it from the front panel opening.
      Ask FixBot
      • Take out three screws from the washer bottom; tilting the unit backward may improve access.
      • Remove two screws from the door-lock facade and lift the facade away.
      • Undo the single screw holding the door lock, lift the lock up, and push it rearward inside the cabinet.
      • Extract seven screws along the top edge of the bulkhead; corrosion may require alternate bits.
      • Open the door, lift it slightly, pivot the front panel forward, and disconnect the left-side harness before removing the panel completely.
      Ask FixBot
      • Unscrew the metal retainer from the damper and separate the two halves with a hook tool.
      • Remove the screw beside the wire-tie anchor that holds the damper harness clip to the bulkhead.
      • Cut the existing cable tie and press the two small wings to release the harness block from its holder.
      • Disconnect the blue damper plug; the adjacent white plug powers the drum light.
      • Pull the damper body straight out of the gasket to remove it.
      Ask FixBot
      • Place the replacement damper between the gasket lips so it rests on the three molded ledges; a small gap above the plastic is normal.
      • Fit the metal retainer around the damper halves, press until it snaps, and reinstall its screw.
      • Reconnect the blue harness plug and lock the harness block back into its holder.
      • Secure the wiring with a fresh cable tie routed through the original anchor.
      Ask FixBot
      • Lift the damper assembly into its opening and reinstall the three Phillips screws.
      • Pull gently on the assembly to confirm it is firmly locked in place.
      Ask FixBot
      • Roll the gasket lip over the front panel rim while wearing gloves to avoid cuts.
      • Use a spring-expander tool, or a cable-tie and wrench method, to stretch the spring clamp and guide the wire around the gasket groove.
      • Release the tool slowly and press the clamp fully into the groove with a hook or screwdriver.
      Ask FixBot
      • Align the front panel on its locating pegs, reconnect the left-side harness, and pivot the panel into place.
      • Reinstall the door-lock screw and refit the facade with its two screws.
      • Replace the seven upper bulkhead screws followed by the three bottom screws.
      Ask FixBot
      • Set the top panel on the cabinet, slide it back, and secure it with three screws.
      • Hook the right side of the interface onto its stud, pivot the left side down, and press until it locks.
      • Install the five dispenser-area screws, matching the coarse-thread pair to the center holes.
      • Slide the detergent drawer back into the housing until it clicks.
      Ask FixBot
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,152 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 142
All Time: 852
