GE Dishwasher Control Board Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Dishwashers use household voltage, which can seriously injure you.
      • Find the dishwasher breaker in the electrical panel.
      • Switch the breaker off, wait a few seconds, then switch it back on to reset the dishwasher.
      • Check whether the controls light up and respond to the Select Cycle and Start buttons.
      • If the controls return, stop here and monitor the dishwasher.
      • If the dishwasher is still dead, turn the breaker back off and leave it off for the repair.
      Ask FixBot
      • Confirm that the dishwasher breaker is off before working underneath the machine.
      • Remove the two screws securing the kick plate with a Phillips screwdriver.
      • Pull the kick plate away from the dishwasher.
      • Remove the strip of noise-dampening foam if it is installed behind the kick plate.
      • Use a non-contact voltage detector near the wiring in the toe-kick area.
      • Do not continue unless the detector shows no voltage.
      Ask FixBot
      • Remove the screw securing the small junction-box cover with a Phillips screwdriver.
      • Pull off the junction-box cover.
      • Press the clip on the dishwasher power connector.
      • Pull the connector down to disconnect power from the dishwasher.
      • Grip the connector body instead of pulling on the wires.
      Ask FixBot
      • Remove the two screws securing the junction-box bracket to the frame with a Phillips screwdriver.
      • Push the bracket back and out of the way.
      • Disconnect the cable that runs to the front panel.
      • Keep each screw group separate so everything returns to its original location.
      Ask FixBot
      • Locate the two front screws with black rubber washers.
      • Remove the two screws with a Phillips screwdriver.
      • Support the tray while removing the second screw so it does not drop.
      • Lower the tray enough to see how the wires are routed.
      • Take a photo of the wire grooves in the tray and frame.
      • The wires must return to these grooves or the tray will not seat correctly.
      Ask FixBot
      • Locate the three connectors plugged into the control board.
      • Press the retaining clip on each connector.
      • Pull each connector straight out of the board.
      • The reddish-brown plug at the back is awkward to reach, so work slowly.
      • Slide the tray out from under the dishwasher after all three connectors are free.
      Ask FixBot
      • Static electricity can damage the control board.
      • Touch bare metal on the dishwasher frame before handling the board, and hold the board by its edges.
      • Remove the screw securing the control board to the tray with a Phillips screwdriver.
      • Press the tabs on the plastic mounting posts inward with the tip of a screwdriver.
      • Lift the control board off the mounting posts.
      • The tabs can be fiddly, so work around the board until each post releases.
      Ask FixBot
      • Compare the old and new boards to make sure the connectors and mounting points match.
      • Mark the old board if the two boards look identical.
      • Keep the old board separate so it does not get reinstalled by mistake.
      Ask FixBot
      • Align the replacement board over the plastic mounting posts on the tray.
      • Press the board down until the plastic tabs hold it in place.
      • Reinstall the control-board screw.
      • Do not forget this screw, because it is easy to miss during reassembly.
      Ask FixBot
      • Slide the metal tray back under the dishwasher.
      • Reconnect all three plugs to the control board.
      • The plugs are keyed, so they should not fit backward or in the wrong place.
      • Press each plug in until its clip seats.
      • Do not force a connector that does not line up cleanly.
      Ask FixBot
      • Lay the wires back into the channels in the metal tray and dishwasher frame.
      • Lift the tray into place while keeping the wires aligned in the grooves.
      • If the tray will not seat, stop and recheck the wire routing before pushing harder.
      • Use a small jar or similar support to hold the tray up while you start the screws.
      • Reinstall the two front screws with black rubber washers using a Phillips screwdriver.
      Ask FixBot
      • Reconnect the cable for the front panel.
      • Pull the junction-box bracket back to the frame.
      • Reinstall the two bracket screws with a Phillips screwdriver.
      • Plug the dishwasher power connector back in until the clip seats.
      Ask FixBot
      • Slide the junction-box cover back into place.
      • Guide the wires into the box if they block the cover.
      • Do not pinch any wires under the junction-box cover.
      • Reinstall the junction-box cover screw with a Phillips screwdriver.
      • If you test before reinstalling the kick plate, secure the junction-box cover first and shut the breaker off again before touching the toe area.
      Ask FixBot
      • Reinstall the noise-dampening foam if you removed it.
      • Position the kick plate at the bottom of the dishwasher.
      • Reinstall the two kick-plate screws with a Phillips screwdriver.
      Ask FixBot
      • Turn the dishwasher breaker back on at the electrical panel.
      • Confirm that the control lights come on and the Select Cycle and Start buttons respond.
      • Run a test cycle and listen for normal dishwasher operation.
      • If the dishwasher still has no power, switch the breaker off and recheck the power connector, front-panel cable, and all three board plugs.
      Ask FixBot
Run a test cycle before returning the dishwasher to normal use. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 155
All Time: 376
